I am seeing this same error in OSX with my Mac Pro using PixInsight 01.08.04.1195 Ripley (x64)
Is it possible to set a setting for an OS X Project that is the "Default Path" variable? Aka, every open/add file operation would start from $PIX_PATH?
Here's what I'm seeing:
- When I go "Open" a file, or "Add Files" in a Process, about 75% of the time, it will take me a few directory levels too high up and go to Documents.
- About 25% of the time, It will take me one level higher up than the a recent file I opened. However, it's not always the last file I opened. For example, sometimes it's from a light_calibrated_cc_reg folder from a project I was working on last week.
Per the suggestions in this thread, I have tried
- Removing the PixInsight folder from my local Library folder. It was regenerated on the next run. However, same behavior.
- Checking to make sure all .fits and .xifs files are not present in ~/Documents.
Attached as "Pic1_AddFileDialog" is what I usually see when I click on an Open or Add File dialog: e.g. ~/Documents
Attached as "Pic2_WhereMyProjectIs" is where my project file, and all my recently opened files are: e.g. ~/Documents/processed_photos/2016_02_08/flame_and_horsehead/
Here is the System Profiler information for the system I am using.
Hardware Overview:
Model Name: Mac Pro
Model Identifier: MacPro6,1
Processor Name: Quad-Core Intel Xeon E5
Processor Speed: 3.7 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 10 MB
Memory: 64 GB
Boot ROM Version: MP61.0116.B15
SMC Version (system): 2.20f18
Illumination Version: 1.4a6
System Software Overview:
System Version: OS X 10.10.4 (14E46)
Kernel Version: Darwin 14.4.0
Boot Volume: Macintosh HD
Boot Mode: Normal
Secure Virtual Memory: Enabled
Time since boot: 8 days 7:31
