Author Topic: Updated ImageRegistration module: StarAlignment bug fixes  (Read 18340 times)
« on: 2008 December 10 11:08:56 »
[Spanish text below]
Hi all,
A new version of the ImageRegistration module (1.2.5.86) is now available for all supported platforms. This version fixes a critical bug in the StarAlignment process. StarAlignment is a tool for automatic image registration that uses stars as alignment references.
We encourage you to update your ImageRegistration module to this new version, as soon as possible.
Special thanks to Nikolay Volkov (Almaty, Kazakhstan) and Yuri Beletski (ESO/Chile) for their help in fixing this bug.
Download Addresses
Linux/X11 32-bit (x86)
http://pixinsight.com/export/ImageRegistration-pxm-x11-x86-20081210.tar.gz
Linux/X11 64-bit (x86_64)
http://pixinsight.com/export/ImageRegistration-pxm-x11-x86_64-20081210.tar.gz
Mac OS X 32-bit (x86)
http://pixinsight.com/export/ImageRegistration-pxm-osx-x86-20081210.zip
Windows 32-bit (x86)
http://pixinsight.com/export/ImageRegistration-pxm-win-x86-20081210.zip
Windows 64-bit (x86_64)
http://pixinsight.com/export/ImageRegistration-pxm-win-x86_64-20081210.zip
How to Install the Module
Linux
1. Exit all running instances of PixInsight, if any.
2. Extract the tar.gz archive and you'll get the module file:
  ImageRegistration-pxm.so
3. Copy the module to the bin installation subdirectory, replacing the previous version.
Mac OS X
2. Double-click the zip archive and you'll get the module file:
  ImageRegistration-pxm.dylib
3. Right-click the PixInsight.app application. It is on the /Applications folder if you copied it to that folder, as usual.
4. From the context menu, select Show Package Contents.
5. Now a Finder window opens for the PixInsight.app folder. Expand the Contents/MacOS/bin folder.
6. Copy the module file (step 2) to PixInsight.app/Contents/MacOS/bin
Windows
2. Extract the zip archive and you'll get the module file:
  ImageRegistration-pxm.dll
3. Copy the module to the bin installation sub-folder, replacing the previous version. If you installed PixInsight on the default location, then the required folder is C:\PCL\bin (C:\PCL64\bin for 64-bit versions).
If you have suggestions or need help, don't hesitate to contact us at support_at_pixinsight_dot_com, or at PixInsight Forum:
   http://forum.pixinsight.com/
Thank you for your continued support,
The PixInsight Team at Pleiades Astrophoto
Hola a todos,
Una nueva versión del módulo ImageRegistration (1.2.5.86) está disponible para todas las plataformas soportadas. Esta versión corrige un error crítico en el proceso StarAlignment. StarAlignment es una herramienta para registro automático de imágenes que utiliza estrellas como referencias de alineación.
Le recomendamos que actualice su módulo ImageRegistration a esta nueva versión tan pronto como sea posible.
Queremos dar las gracias a Nikolay Volkov (Almaty, Kazajistán) y Yuri Beletski (ESO/Chile) por la ayuda prestada para resolver este problema.
Direcciones de Descarga
Linux/X11 32 bits (x86)
Linux/X11 64 bits (x86_64)
Mac OS X 32 bits (x86)
Windows 32 bits (x86)
Windows 64 bits (x86_64)
Si tiene problemas para acceder a las direcciones anteriores (por ejemplo porque aparecen cortadas en el correo que ha recibido), hay una versión HTML de este correo en PixInsight Forum:
  http://pixinsight.com/forum/viewtopic.php?t=953
Cómo Instalar el Módulo
Linux
1. Termine todas las instancias de PixInsight en ejecución, si tiene alguna.
2. Extraiga el contenido del archivo tar.gz y obtendrá el archivo del módulo:
3. Copie el módulo a la subcarpeta bin de instalación, reemplazando la versión anterior.
Mac OS X
2. Haga doble clic en el archivo zip y obtendrá el archivo del módulo:
3. Haga clic con el botón secundario del ratón en la aplicación PixInsight.app, que estará en la carpeta Aplicaciones (/Applications) si la copió a esa carpeta, como es usual.
4. Desde el menú contextual, seleccione Mostrar Contenido del Paquete (Show Package Contents).
5. Ahora se habrá abierto una ventana de Finder para la carpeta PixInsight.app. Expanda la carpeta Contents/MacOS/bin.
6. Copie el módulo (paso 2) a PixInsight.app/Contents/MacOS/bin
Windows
2. Descomprima el archivo zip y obtendrá el archivo del módulo:
3. Copie el módulo a la subcarpeta bin de instalación, reemplazando la versión anterior. Si instaló PixInsight en la ubicación por defecto, entonces la carpeta en cuestión es C:\PCL\bin (C:\PCL64\bin para versiones de 64 bits).
Si tiene sugerencias o necesita ayuda, no dude en ponerse en contacto con nosotros en support@pixinsight.com, o en PixInsight Forum:
Gracias por su constante apoyo,
El Equipo de PixInsight en Pleiades Astrophoto
