Hi there !
I'm using PI for some months and everything worked fine till now. I bought a Moravian CCD G2-8300 and I wanted to work on its first lights. Unfortunately, nothing works...even if I use the AIP process icones.
Let me explain you :
- I shoot my calibration files : Darks, Offsets and Flats with the same conditions than the lights.
- I made my masters with the AIP process icones (so parameters are correct cos lots of people use them without any problem)
- I calibrated the lights with the masters. Surprise : my lights were a lot darker than the originals files. Well, as I never did it with a CCD, I thought "Oh...nevermind, maybe that's normal !" (
https://www.dropbox.com/s/xk744l3et431zom/Image%201.jpg?dl=0)
- I proceed with the Stellar Alignment but...
Registering target image 1 of 84
Loading target file:
C:/Users/.../Pictures/M42 07_01_16/C_HA_0096_1.xisf
Loading image: w=3358 h=2536 n=1 Gray Float32
25 FITS keyword(s) extracted.
Structure map: done
Detecting stars: done
11399 stars found.
* Reference image: Limiting to 2000 brightest stars.
* Target image: Limiting to 2000 brightest stars.
Matching stars: done
*** 0 star pair matches found - need at least six matched stars.
* Previous attempt failed - this is try #2
useScaleDifferences=false
* Previous attempt failed - this is try #3
useScaleDifferences=true
* Reference image: Limiting to 250 brightest stars.
* Target image: Limiting to 250 brightest stars.
Matching stars: doneAfter a few tries, that made me upset : stars are almost at the same place on the lights files !
So, I thought the problem would come from the dark images after image calibration.
I asked why to different Pixinsight users I know and they told me that wasn't normal at all to have darker calibrated images even after STF...(Background is BLACK)
CALIBRATION WITHOUT MASTER OFFSET
So we tried to find why the calibrated images were so dark : finally, I tried a calibration without the Master Offset and the result was good. So, for me, the problem comes from the master offset
NEW MASTER OFFSET
So convinced that the problem came from the master offset, I've taken 80 new offset and made a new master offset with them. Tried a calibration but always the same results.
I also tried with an offset in place of the Master Offset and the resulting image was clear enough to perform a star alignment...but still not with the Master Offset.
https://www.dropbox.com/s/mhlf87x9mdmutx0/Capture%20d%27%C3%A9cran%202016-01-11%2012.04.29.png?dl=0)
A NEW DAY, A NEW HOPE...well...kind of...
After working on this problem during hours yesterday, I went to bed thinking that tomorrow will be a better day...fool was I ! Today, I tried a new calibration with the same offset and same parameters than yesterday and...I obtain the SAME dark result than with the Master Offset...what the hell happens to Pixinsight ? I'm getting crazy today !
There is the process icones that I use :
https://www.dropbox.com/s/8s9oc8ngecim096/1_JMpretraitement-vp2.xpsm?dl=0The Master offset :
https://www.dropbox.com/s/1eu23ngoc583949/MasterOffset.xisf?dl=0Offset :
https://www.dropbox.com/s/zkh1ajknluea1cp/O__0002.fits?dl=0A light image :
https://www.dropbox.com/s/hskaxxsx9zrfgzj/HA_0018.fits?dl=0Help me please...
