Author Topic: Lum or Duplicate images for masking?  (Read 2457 times)
Offline LarryC
« on: 2016 January 06 18:25:02 »
My processing has really improved with the increasing use of a number of masks in my DSLR image workflow in Pixinsight, based on what I've learned from experimentation and numerous tutorials.  One thing I have not figured out is why, or when, to use an extracted luminance layer vs a duplicate of the image as a mask.  It seems to me that both accomplish pretty much the same thing and both can be tweaked to achieve greater discrimination with HT, as necessary.  Luminance layers remind me more of the masks I'm used to in Photoshop, so I'm included to use them in all cases, but is there a reason to use a duplicate RBG layer instead?
Larry
Re: Lum or Duplicate images for masking?
« Reply #1 on: 2016 January 07 06:56:03 »
Hi Larry,
You can use either a grayscale image or an RGB color image to mask an RGB color image in PixInsight. It depends on what you want to do.
When a grayscale image acts as a mask for a color image, it is applied equally to each color channel to filter maskable processes. When the mask is an RGB color image, each mask channel is used separately for its corresponding channel of the masked image, that is, it works like three separate images, each one with its own mask. Note that a color image cannot be a mask of a grayscale image.
When masking color images, most of the time you want the same mask applied to all color channels, so in most cases you'll use a grayscale mask image. Masks can be generated in many ways and for many purposes. Extracting the lightness component of a color image is just one, and typical, way to obtain a general-purpose mask.
Offline LarryC
« Reply #2 on: 2016 January 08 08:49:44 »
Juan,
Thanks for the explanation.
