Author Topic: How to use rgb stars in a narrowband image?  (Read 4814 times)
Offline dcastroimage
« on: 2016 January 06 16:07:09 »
Need to remove stars from narrowband image and replace with rgb stars
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: How to use rgb stars in a narrowband image?
« Reply #1 on: 2016 January 07 08:44:14 »
Simplest way would be to do the following steps:
1.  Make a star mask of the NB image covering all the stars you want to replace
2.  Load the RGB image into pixelmath with no other expression, just the file name
3.  apply pixelmath to the NB image protected by the star mask (just pull the little triangle at the bottom left of the tool onto the NB image)
That should do it
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline RickS
« Reply #2 on: 2016 January 07 16:34:20 »
I usually add RGB stars to a NB image by extracting the L, a* and b* channels from each then using PixelMath and a star mask to blend the a* and b* from the RGB with the a* and b* from the NB image. Recombine the L, a* and b* for the NB image and voila! Sounds easy but there's always a bit of messing around and tuning for any specific image.  The advantage of this approach is that the original NB star profiles are preserved and only the colour is changed.
Rick.
Offline jkmorse
« Reply #3 on: 2016 January 08 08:21:37 »
Rick,
I like yours better.  To really get mine to work you pretty much have to kill the NB stars which can result in replacing nice tight stars with bloated ones.
Jim
Apogee Aspen 16803
« Reply #4 on: 2016 January 08 09:18:11 »
Jim
When making the star mask from the NB image use a structure mask or a smoothness of 0 or 1 in starmask. If it needs a little edge flaring use a very, very minimum amount of convolution. That will usually take care of the bloated stars. You can also use a little erosion in MorphologicalTransformation on your star mask to tighten to reduce the size of the stars in the mask if they are bloated. I like to apply the mask inverted to my working image. Then I tweak the mask with Morph and watch the result in real time in the working image. It's a lot easier to tell when I have the stars covered perfectly.
Offline Dimitris Platis
« Reply #5 on: 2016 January 08 10:18:44 »
U can really use narrowband stars with excellent results (no magenta) as long as u dot the following.,,,
1) Remove stars by Structure map + Morphological Transformation
2) Create Difference Map
3) Linear fit all filters (Ha, OIII, SII)
4) Add stars to each filter
5) SHO script
Offline jkmorse
« Reply #6 on: 2016 January 11 07:27:05 »
Mike,
Great suggestions.  I will add them to my workflow.
Jim
Apogee Aspen 16803
« Reply #7 on: 2016 January 27 16:44:46 »
Thanks for all the suggestions guys
