Author Topic: OSC Flats...  (Read 2251 times)
Offline cardiofuse
OSC Flats...
« on: 2016 January 05 18:12:53 »
As basic as this sounds, I wanted to be clear.  When I create a MasterFlat with my one shot ST8300 RAW subs do I need to deBayer them at any point or just proves the RAW frames as any other Flats?
Rick
cardiofuse observatory
Panama City
Re: OSC Flats...
« Reply #1 on: 2016 January 05 18:57:14 »
no, they do not need to be debayered.  the master flat (and master dark and master bias) should all be in CFA (bayer) format, either mono or 3-channel.
after calibration of the lights, you debayer the calibrated lights, then run star alignment, and finally imageintegration.
Offline mmerino
Re: OSC Flats...
« Reply #2 on: 2016 January 06 07:16:52 »
When using Cosmetic Correction, when do you debayer,  before or after CC?
Miguel
Offline cardiofuse
Re: OSC Flats...
« Reply #3 on: 2016 January 06 08:38:37 »
I believe it would be as a work flow:
image calibration
Cosmic Correction
Batch Debayer Script
Star Alignment
Image integration
Rick
Panama City
