Author Topic: Need help! Invalid image geometry message calibrating DSLR lights  (Read 3024 times)
Offline dcastroimage
Please help me! I get a message. ...invalid image geometry when trying to calibrate my osc dslr lights. Lights are 28x300sec iso 400. Masterdark is composed of 30x300sec iso 400. Masterbias is composed of 30x1/4000 at iso 400. Some lights will make it through, most wont. Please help.
Offline aworonow
    • Faint Light Photography
Re: Need help! Invalid image geometry message calibrating DSLR lights
« Reply #1 on: 2016 January 05 16:00:08 »
Sounds like your images may not all be of the same size (number of pixels in X and Y). Perhaps you cropped some and not others? Or maybe some are debayered and others not? Or maybe different debayering was used on different images?
One way to check image size (probably there's an easier one) is, under Image>new click "set as active image" and the pixel dimensions will appear.
Are all the images color? I don't think PI takes kindly to darks/flats that are grayscale operating on images that are color.
Hope that helps.
Alex
« Reply #2 on: 2016 January 05 16:21:33 »
Thanks for replying.  The images are straight out of backyard eos.  I guess they are already debayered. They're all the same size as far as I know. They were shot consecutively using same camera. The bias and darks have not been modified in anyway. Neither has the lights. I took the lights lastnight and took them from folder on computer straight to image calibration process in pixinsight.  The darks and bias masters are the 3rd round of masters that ive made due to this problem. Each time I produce the masters, I get this problem with seemingly random results on random lights in the dataset. And ive tried multiple 300sec iso 400 datasets. Ive also tried to calibrate with just the masterdark and just the masterbias with no changes.
« Reply #3 on: 2016 January 05 16:24:58 »
The darks and bias were taken with backyard eos as well. No croppi g of any kind on anything
« Reply #4 on: 2016 January 05 17:29:40 »
you probably need to set the DSLR_RAW module to "pure raw" (in the format explorer, double click DSLR_RAW).
what's likely happening is the camera was set to write the camera orientation to the CR2 files. as the telescope tracks the camera goes from landscape to portrait mode. when not in "pure raw" mode DSLR_RAW may be reading this flag and changing the image geometry from WxH to HxW.
« Reply #5 on: 2016 January 05 17:58:03 »
Looks to be working. I have 28 to calibrate so itll be a while but its already let some through that didnt before. You're the man! Ive been struggling with that for a while.
« Reply #6 on: 2016 January 05 18:05:13 »
All 28 made it! Ask and ye shall recieve. Thanks again!
