Author Topic: Crash with read only directory  (Read 2623 times)
Offline jochta
« on: 2016 January 04 11:42:04 »
Here's a crash report using PixInsight Core 01.08.04.1195 Ripley (x64) on Mac.
ImageCalibration process and select an Output directory which is read only (not writable). Output extension .xisf. When you run the process on a batch of .fit files and it tries to write the first calibration file PI crashes. If you leave the Output extension box empty (assumes .fit) and run the process. It runs with error messages appearing in the Process console but PI doesn't crash.
Regards
John
Re: Crash with read only directory
« Reply #1 on: 2016 January 07 03:11:48 »
Hi John,
Bug confirmed. This is a small bug in the XISF support module, which I'll fix in the next version. Thank you for reporting.
Offline jochta
« Reply #2 on: 2016 January 10 14:24:37 »
No problem. It took me a few restarts to realise what I was doing wrong! I'd accidentally chosen a write protected external drive to write to  ::)
John
