Author Topic: Modifying and saving Process Icons  (Read 3920 times)
Offline mmerino
« on: 2016 January 03 10:36:13 »
I am still struggling to learn all the "tricks" to setup correctly my interface in PI. I am a bit confused as how to save process icons (which I have on my desktop) when I modify it's parameters.
Here is how I have things setup: I have created several process icons (with certain parameters) renamed them and saved them to my "Icons" folder. I have then selected all the icons on the desktop, right-clicked and selected "Save Selected Icons" with the name "PREPROCESSING". I have included the file path of this icon in the startup.scp file, so that every time I launch PI, they are loaded automatically.
Now, the problem is when I open a process icon and change a parameter, how do I update the original one? I have tried creating a new icon and saving it with the same name as the original (overwriting it) but for some reason the old one opens when I reboot PI.
I appreciate any suggestions! Thanks,
(Note: In some cases, the Icon Identifier is different from the Icon file name -my mistake!: how can I identify which icon file corresponds to which Icon in PI?)
Miguel
Re: Modifying and saving Process Icons
« Reply #1 on: 2016 January 03 17:43:04 »
Hi Miguel, I think that you have to replace your modified process icon an then save again your favorite list of icons named "PREPROCESSING"
Saludos, Alejandro.
Offline mmerino
« Reply #2 on: 2016 January 04 04:05:47 »
Thanks Alejandro! Works great! (I didn't know I could drop a new instance on top of another existing Icon to replace it).
Miguel
Offline jerryyyyy
    • Astrobin Images
« Reply #3 on: 2016 January 04 07:04:02 »
In my own case I use data from different telescopes so have some processing icons (like BatchProcessing) which have parameters unique to that set up (e.g. Darks).
I have them set up so that they form an outline of my workflow (as in object oriented programming), so it looks somewhat like this:
Image Integration and renaming
RGB image formation (Including NB) and processing
L formation
Integration of L & RGB
Final Noise Reduction (if needed) including star debloating
Final checks e.g. ICC profile
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline mmerino
« Reply #4 on: 2016 January 05 04:30:13 »
Thanks Jerry, that's a useful idea.
Miguel
Offline mmerino
« Reply #5 on: 2016 January 05 04:42:47 »
Today I redid from scratch all the process icons again with new parameters. I saved them individually, and then saved all together with the name "PRE-PROCESSING".
I closed PI and when I opened it up again I get an error message "Unexpected (line=579, column=61)". I click ok, then I get this message (I attach file). I click Ok.
When I try to load "PRE-PROCESSING.xpsm" I get the same error message. Nothing opens.
Now I have all my process icons saved but cannot open them all together (If I open one, the other opened one dissapears...).  How can I create again the "PRE-PROCESSING" icon which contains the other process icons if I cannot open them all together? (I have spent a couple of hours creating all these icons!).
Thanks for your help!
Miguel
Offline jerryyyyy
    • Astrobin Images
« Reply #6 on: 2016 January 05 08:52:11 »
Miguel
FYI, here is a screen shot.  This is a work in progress and the content is a denoising problem, but I think you can see the outline of the icons.
Takahashi 180ED
Astrophysics Mach1
« Reply #7 on: 2016 January 05 13:46:43 »
Miguel
you need to use "merge process icons" if you want to open multiple process icons from different files.
Offline mmerino
« Reply #8 on: 2016 January 06 07:00:52 »
Thanks Rob. That's correct (I found that out trying several options!). The problem was that an icon was corrupted (I opened one by one till I found the error) so the group of icons could not be loaded.
Miguel
