So here's where the new research has taken me, I obsess over upgrading as I don't do it that often, I looked at the i7-5020K CPU vs the i7-6700K CPU. The i7-6700K is clocked at 4GHz and is a quad core processor that has 8 threads. The i7-5020K is a 6 core/12 thread processor clocked at 3.3GHz. Now maybe it's a bit harder to figure than my approach but my thinking is that the only program other than possibly the OS, Windows 10 Pro 64, so greater overall performance improvement would likely be seen with the i7-6700K. But from the aspect of PixInsight using all cores and threads it would seem the i7-5020K would maybe eek out a slightly higher improvement. The difference is in the motherboards. The i7-5020K requires a LGA2011-V3 socket motherboard and from what I've seen of most of those they are aimed mostly at gamers. Almost all had 3-4 PCI Express 3.0 x16 slots that would not get used. I use one high quality video card and would prefer to have PCI slots available for add-on cards. If this computer down the road would end up out in the observatory I end up with few to no ways to add serial cards for the mounts, focusers, flat panels, and so on. From what I've seen so far it would likely be a pairing of i7-6700K/Z170-A from Asus or i7-5020K/Asus X99-A. Both would need 32GBs of DDR4 RAM, use the existing SSDs I already have.
Suggestions and opinions always welcomed. Building computers has gotten way more complicated that the days of just choosing a CPU based on cpu speed. Remember Celeron vs Pentium, Core 2 Duo Dual Core vs Core 2 Duo Quad Core, pretty much based on rated MHz/GHz ratings and # of cores. Seems now everything is based on gaming needs and at 61 I have no intent of "gaming" other than the Solitaire/Mahjong windows games. I have enough distractions to keep me busy. Amazing how you loose a ton of time looking at Facebook.
