Author Topic: Problem with module InterChannelCurves in New version 1195  (Read 6939 times)
Offline freddy1
Hello everyone:
I have a problem with the new version 1195; when I try to install the unoffitial module InterChannelCurves an error message appear.
Could anybody knowo how is the way to run this module in 1195 version?
I apreciate the comments
Thanks.
Federico
Offline sreilly
Re: Problem with module InterChannelCurves in New version 1195
« Reply #1 on: 2015 December 31 07:27:57 »
What OS version are you using?
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline sreilly
« Reply #2 on: 2015 December 31 07:49:29 »
I just downloaded and install 5 of the modules without issue on my Windows 10 Pro 64 bit system.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
« Reply #3 on: 2015 December 31 09:07:18 »
I'm also having no problem under Windows 7. The latest version runs fine. If your running OSX then your out of luck right now. There  is no version for OSX currently so you might want to check with Carlos about when a new version might be ready. Here is a link to Carlos's website with the latest versions of his modules. http://www.astrophoto.cl/Research.html
Offline freddy1
« Reply #4 on: 2016 January 02 15:58:18 »
Gentleman, Thanks very much !!! :D :D I'm so happy now!!
Mike: many thanks by the link; I update in my files the Carlos's PCL module and now I can load in new Px #1195 version. The problem is that I try to load any kind of old version of this modules... ? I donĀ“t know.....
Thank very much by your help
Best Regards
Federico
Offline freddy1
« Reply #5 on: 2017 August 10 18:40:32 »
Hello Everybody
I can not run the Carlos Milcovic's PCL-Processing modules at 1.8.5 PI New version
Could any body Know if there is an updated version of this process modules?
Thanks by your helps
Federico
