Author Topic: Erosion Filter?  (Read 2523 times)
Offline sreilly
Erosion Filter?
« on: 2015 December 23 15:11:18 »
I have to admit I'm not familiar with the Morphological Process at all but understand that it might play a role in eking out some really faint detail in my recent image of LBN576 where the nebula makes a very faint appearance. This image is a LRGB image consisting of 10 hours luminance data, 3 hours each of red, green, and blue. Processed in PixInsight, the image can be seen here http://www.astral-imaging.com/LBN576-RC2.html What I can't seem to find is some idea on how to use this tool to get the detail out. Any suggestions would be greatly welcomed.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline gvanhau
Re: Erosion Filter?
« Reply #1 on: 2015 December 28 11:56:56 »
Hello Steve
You could try the following:
Frist make a star mask:  take for noise threshold the aproximate background level of your image; for scale take about 5 or 6;  set structure grouths to 0; For smoothness use about 8; check contours; leave the rest as default and apply.
This should give you a mask of donuts arrount most of the stars.
Apply the mask to your image.
Now, with The morfological process, use a structure about 5 or 7 and select circle shape.
Select erosion, select iterations according to the effect you want.
Select amount to a small value (0.1 to 0.3)
Apply (try first on a preview).
This should reduce your stars ..... and allow space to enhance the DSO.
Regards
Geert
Geert Vanhauwaert
Offline sreilly
Re: Erosion Filter?
« Reply #2 on: 2015 December 29 08:22:47 »
Thank you Geert, I'll try this soon.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
