Author Topic: Core version 01.08.04.1195 access vialation on startup..  (Read 3748 times)
Offline multispeed
« on: 2015 December 21 00:15:20 »
Hello i updated to the new Vers.
(Uninstalles the old--then new)
i get this tiny window on startup
i use win 7 Proff. 64bit.
hope there is an solution;)
cs
Werner
EQ8, SW 12" f/5 PDS, G2-8300, 36mm Baader LRGB Ha OIII SII, USB Focus Heavy
EQ5 Skyscan, SW 8" f/5 PDS, 1000Da, 600Da,
Sw 6" f/5
Re: Core version 01.08.04.1195 access vialation on startup..
« Reply #1 on: 2015 December 21 01:54:55 »
Not reproducible.
Did you reboot your computer after uninstalling the old version - before installing the new one? See FAQ 3.3. The reboot isn't normally necessary on Windows 8/8.1/10, but it is required in most Windows 7 installations.
Offline multispeed
« Reply #2 on: 2015 December 21 03:19:41 »
Hello,
unistalled it before .
now unistalled,reboot,new install(in an other directory for safty)..=same result :-[
so no one else has this ?
cs
Werner
Sw 6" f/5
Offline multispeed
« Reply #3 on: 2015 December 21 13:19:06 »
where can i get the old version deleted it ...before testing :'(
cs
Werner
Sw 6" f/5
« Reply #4 on: 2015 December 22 00:40:32 »
Are you using a Dell computer, by chance? If yes, see this post for a probable solution.
Offline multispeed
« Reply #5 on: 2015 December 22 00:52:56 »
Hello,
no its an Samsung RV720...
i will wait for next release hope it works...for me again
maybe it helps..
Merry Christmas...
cs
Werner
Sw 6" f/5
« Reply #6 on: 2015 December 22 01:32:21 »
Merry Christmas also to you.
I hate to say that I have no clue what can be causing this problem on your machine. AFAIK this has not been reported by other users, and we cannot reproduce it on any of our working/testing machines, on any platform. Can you try with a different machine?
Offline multispeed
« Reply #7 on: 2015 December 22 02:32:45 »
Hello,
on my Tower I7 it works..;) thank god for usb sticks;)
so i need only cs to get data ;)
so maybe close this thread or leave it ..maybe someone has this too...
cs
Werner
Sw 6" f/5
Offline multispeed
« Reply #8 on: 2015 December 28 02:06:31 »
but "older" Versions are not anywhere to dl?
cs
Werner
Sw 6" f/5
Offline multispeed
« Reply #9 on: 2016 June 25 23:55:16 »
Hello,
so problem still there...why it is not possible..to leave older versions on the distribution server if something like this to occurs.
To use an Programm that i have paid.
https://www.dropbox.com/s/v9iogy20bkfwork/Screenshot%202016-06-18%2013.44.22.png?dl=0
i tryd different grafik settings...admin rights...no success :'( is there an error log from pixinsight?
Or u can send me an link to an Version befor this.
would be much respected 8)
« Last Edit: 2016 June 26 00:00:41 by multispeed »
cs
Werner
Sw 6" f/5
« Reply #10 on: 2016 June 28 08:33:46 »
Once a new version has proven stable and has no known and reproducible problems, we always remove all previous versions. We have very good reasons to follow this policy.
The problem you are reporting (crash and program exit upon startup) is extremely strange, and AFAIK has not been reported by other users. I'll see if we can do something about your request.
