Author Topic: PI 1.8.4.1195 crashes when opening or saving image  (Read 2857 times)
Offline astrovienna
« on: 2015 December 20 13:56:37 »
I updated today, and I can't open or save individual images, or open project files from within PI.  I can open a project file if PI is not already running (by double-clicking on that project file).  When I click on Open or Save, a Win Explorer box opens, but then PI crashes, and I get the report below.  This is Windows 8.1.   I tried all the usual things - uninstall/reinstall with reboot, but no change.  Any ideas?  I reverted to 1.08.03.1123, which seems to be working without trouble.
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   PixInsight.exe
  Application Version:   1.8.4.1195
  Application Timestamp:   567420a5
  Fault Module Name:   ntdll.dll
  Fault Module Version:   6.3.9600.18146
  Fault Module Timestamp:   5650b9bb
  Exception Code:   c0000005
  Exception Offset:   00000000000356b1
  OS Version:   6.3.9600.2.0.0.768.101
  Locale ID:   1033
  Additional Information 1:   7004
  Additional Information 2:   7004f825799b2d4a7ac0b933709d0693
  Additional Information 3:   1368
  Additional Information 4:   1368b8c004f591a752a36f44947867ba
Offline Sean
    • My Personal Website
Re: PI 1.8.4.1195 crashes when opening or saving image
« Reply #1 on: 2015 December 20 16:12:00 »
Are you running PI on a Dell computer? If so, this posting may help: http://pixinsight.com/forum/index.php?topic=9190.0
Sean
Offline astrovienna
« Reply #2 on: 2015 December 20 17:22:54 »
Thanks Sean.  Yes, that's exactly it.  I'm a non-technical type (the bane of programmers everywhere  :) ) and of the suggestions given by Juan in that thread, the only one I felt comfortable doing was to uncheck Edit>Global Prefs>File IO Settings>Use native file dialogs.  No luck, though.  When opening/saving, PI reports "no disk in drive," and clicking through eventually yields "PCL Win 32 system exception."  Sigh.  It's really surprising Dell has done nothing to solve this.  I'll have to stay with 1.8.3 for now.
Kevin
Offline astrovienna
« Reply #3 on: 2015 December 20 18:03:14 »
I cranked up my risk tolerance one notch and followed Juan's first suggestion, to remove Dell Backup and Recovery, and that seems to have solved the problem.  I set the File IO Settings back to use native file dialogs, and it still seems to run fine, so I'll leave it as is for now.  Thanks Sean.
Kevin
