Author Topic: File order in Blink  (Read 2837 times)
Offline niteman1946
File order in Blink
« on: 2015 December 17 05:49:51 »
It seems to me that the files in Blink are randomly thrown in.  Here's a shot of some of mine.  The 6 digit number to the far right of each file is the timeline (i.e. hour, minute, second).
I've not found a way to organize the files to present them sequentially.
Any help here would be appreciated.
Mark
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: File order in Blink
« Reply #1 on: 2015 December 17 08:30:18 »
If you put in an image number before the time line that should solve the problem.  I number mine as a matter of course (easy to do in all the capture software I am aware of).  With the numbering, Blink lines them up in the order taken automatically.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline niteman1946
« Reply #2 on: 2015 December 17 08:54:54 »
Thanks Jim,
I suspected that would be the case.  I'll see what SGPro can do.
BTW, keep up the good work on your crib sheet.
Mark
« Reply #3 on: 2015 December 17 10:26:17 »
in SGP i am using the following format string:
%dt\%tn_%ft_%fe_%dt_%tm_%ess_bin%bi_%su
that puts the date first, (in YYYY-MM-DD format) then the time (in HHMMSS format). that seems to keep everything in order in Blink.
Offline niteman1946
« Reply #4 on: 2015 December 17 12:19:26 »
Hi Rob,
yes I see several ways of numbering that will work.
Thanks for your suggestion.
Mark
Offline niteman1946
« Reply #5 on: 2015 December 18 07:49:55 »
I placed SGPro's "frame number (%fz)" directly after the "target name".  This assigned a sequential number to each file and allowed the Blink tool to properly organize them.
Thanks for your help.
Mark
