Author Topic: Flat overcompensating  (Read 2582 times)
Offline HSauber
« on: 2015 December 15 05:06:41 »
Hello,
as a newbie to PixInsight I have a difficulty with calibrating images with  flat frames.  The problem is clearly seen in the screenshot www.pisam.de/Astronomie/ttttt/ScreenshotPICal.jpg. In the raw image I have vignetting and some dark dust doughnuts which after calibration with a flat image are still visible and appear brighter as they are supposed to be. To exclude any other side effects I used only a single light frame and a single flat frame. Most likely I overlooked some detail in handling PixInsight properly.  For any hints I would be very grateful.
Herbert Sauber
Mittenwalde, Germany
Offline chris.bailey
Re: Flat overcompensating
« Reply #1 on: 2015 December 15 06:52:47 »
Herbert
Try adding a Master Bis frame into the calibration and tick the 'calibration' box under the master flat. Both light frames and flat frames need to be bias subtracted for the flat to work properly.
Chris
Offline HSauber
« Reply #2 on: 2015 December 15 11:45:34 »
Herbert
Chris
Thanks Chris
This does actually improve things. But the corners of the calibrated image still look brighter as they should.
Herbert
Offline gvanhau
« Reply #3 on: 2015 December 16 04:52:47 »
Geert Vanhauwaert
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #4 on: 2015 December 16 07:59:35 »
+1 on Geert's post.  Works like magic.
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
