Author Topic: ** Warning: Inconsistent pedestal values detected - PEDESTAL keyword not created  (Read 2277 times)
Offline LMLeitch
I took 24 dark frames in the .FIT format and used the BatchFormatConversion script to convert the raw darks to .XISF format.
The next step was to use the ImageIntegration process to produce a master dark. No bias frames were used.
The last line in the Process Control window was
"** Warning: Inconsistent pedestal values detected - PEDESTAL keyword not created"
I searched and found a problem similar to this where the user disable "Use File Cache". I tried this and the results were the same.
I will be thankful for any/all help.
Larry Leitch
