Author Topic: LinearFit producing odd results  (Read 2489 times)
Offline MikeOates
« on: 2015 November 28 05:11:48 »
I have an odd problem using LinearFit.
I have a 3 panel mosaic (landscape format) and after I had made the mosaic and combined the mono images to get RGB, one panel was rather green. So I went back to the separate integrated panels and did a LinearFit using the middle panel as the reference image. But the other panels turned posterized. See the image below showing the before and after with just STF active.
I also did the same by cropping the borders off, but that did not help. It was panel6 that originally had a green cast.
The .xisf  files for all three integrated green panels are here to try with:
http://www.mikeoates.org/pi/green_integrations_ngc7000.zip
Each panel is made from 15 x 600s subs. They were imaged on different nights so they are bound to be different hence the need for a LinearFit.
Using PixInsight 1.8.4.1193
I must be doing something stupid! so I hope someone can help
Re: LinearFit producing odd results
« Reply #1 on: 2015 November 28 05:54:02 »
Try clicking the 24 icon for 24 bit STF. That should take care of the posterized look.
Offline cfranks
« Reply #2 on: 2015 November 28 13:34:24 »
Mike,
I had a similar problem and Juan kindly told me why!  http://pixinsight.com/forum/index.php?topic=7713.msg51061#msg51061
Charles
Offline MikeOates
« Reply #3 on: 2015 November 28 15:47:05 »
Mike,
Yes I tried that, if does show a better image, but it is changed so much and a 24bit stf should not be needed.
Charles,
Thank you for the pointer, makes sense. I will have to do some manual adjustment to match the panels. I will have to think about that! possibly using pixel math.
So if anyone has a method for doing this and still keeping the images linear, I love to hear from you.
Thank you,
