I'm becoming more confused. If I run the BPP script I have no information to put in the cosmetic correction section, but it's going to debayer after calibration of lights and then register them and integrate to make a single master. When and how do I do cosmetic correction in that case?
And what about the warning that integration of lights won't be optimal?
From what I can understand of Harry's video, he first uses BPP with calibrate only checked, then exits to do something else and comes back....
All is all, it seems easier to me to do things in separate steps, following a careful cribsheet.
But I'm back to questioning the right sequence. Here's what I'm doing and where the hitch is:
using a DSLR, setting PI to Pure RAW
not using darks for now, due to concerns I have seen raised
create a master bias (to be used for several months, as long as I'm shooting with the same camera at the same ISO)
create a superbias -- but its use is being questioned for now
calibrate flats with master bias (or superbias)
integrate calibrated flats to a master
calibrate lights with master flat
run cosmetic correction on calibrated lights -- BUT all .xisf files are grayed out in the cc dialog
debayer cc lights should be done here
select good lights (cosmetically corrected and debayered) with SubframeSelector
register selected lights
integrate to a single image
crop
correct gradients and vignettes
background neutralization
color calibration
then a lot more I haven't gotten to yet
Any advice on the path through the woods will be greatly appreciated! Thanks!
