Author Topic: Higher SNR with rejection than without rejection  (Read 2162 times)
Offline Francesco Wueest
« on: 2015 November 18 04:56:53 »
Hi all,
I have sometimes the problem, that my SNR is higher with rejection than without rejection. Following the ppt from J. Gallego about image integration, I do first an image integration without any rejection and taking the SNR as the "to achieve SNR with rejection".
But sometimes, when I use i.e WSC I get a higher SNR value than without rejection. Is this a common problem or did I not get the point?
without rejection
Gaussian noise estimates : 1.4090e-004
Scale estimates : 2.4479e-004
Location estimates : 3.7900e-003
SNR estimates : 6.5914e+003
Reference noise reduction : 1.6721
Median noise reduction : 1.7838
with WSC
Gaussian noise estimates  : 1.3717e-004
Scale estimates           : 2.3759e-004
Location estimates        : 4.9136e-003
SNR estimates             : 7.0943e+003
Reference noise reduction : 1.6671
Median noise reduction    : 1.7785
Has anyone an idea?
Greetings
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: Higher SNR with rejection than without rejection
« Reply #1 on: 2015 November 18 08:59:07 »
Fancesco,
Its not a problem, its the whole point of the exercise.  Note the title to Gallego's presentation, namely increasing Signal/Noise ratio (SNR) through rejection.  My understanding is that since that presentation was done, there have been updates and name changes in the ImageIntegration tool.  It is also my understanding that the number he uses for what you are trying to match up between the no rejection case and the rejection is not the SNR estimates but instead the reference noise reduction.  That number is the theoretical maximum benefit you can get from noise reduction.  If you go above that number you are rejecting signal and if you are below you are not rejecting as much as you can.  But the goal throughout is to use the rejection tool to increase SNR which is what the exercise is all about.
Looking at your particular case, you are close since the reference noise reduction numbers are close in both cases, though you could tweak your rejection settings to get even a little closer.  My rule of thumb, however, is if you apply more rejection (i.e., use a lower rejection number) and you see no improvement, then use the highest setting (with the least rejection) that gives the same result to avoid eliminating signal.
Hope that helps,
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
