Author Topic: Use of RGBWorkingSpace Process  (Read 2018 times)
Offline javajunkie2121
« on: 2015 November 17 16:14:15 »
Hi All:
I'm trying to determine when I should be using the RGBWorkingSpace process with LRGB (+/- NB) image processing.
I've seen some refer to setting weights to 1:1:1 in RGBWorkingSpace before extracting the L component from RGB to LinearFit to Lum master before LRGBCombination.  I've seen other tutorials mentioning RGBWorkingSpace when combining NB with R,G,B channels.
Should I be using this process at the start of every project, and perform it once as a part of the saved project for all future processing steps? Or must this be done repetitively before certain steps?  Can this be set to be a default for all processing?
jeff
