Author Topic: GradientHDRCompression  (Read 2675 times)
Offline andrewluck
    • Andrew's Astronomy Blog
« on: 2015 November 02 13:20:43 »
I'm having some problems with GradientHDRCompression with the 1185 release. Preview looks as if it works correctly but when I apply the process to the image the result is very much darker and looks nothing like the preview.
I can post an example if required.
Andrew
Andrew
Avalon Linear Fast Reverse
Tak FSQ-85ED
Moravian G3-16200
QHY9C
Re: GradientHDRCompression
« Reply #1 on: 2015 November 02 16:00:51 »
Hi Andrew, I think that this is not related to version 1185 or a bug. The image that you see in the preview is not going to be the same after applying to the image. You may try working with previews.
however I've never achieved approximate results between previews and RealTime
From documentation:
Note: The process offers a realtime preview functionality (experimental) that tries to generate an approximation of the whole processed image.
Saludos, Alejandro.
Offline andrewluck
« Reply #2 on: 2015 November 07 07:38:27 »
Hi Alejandro
Thanks for the information. I've got so used to relying on previews I forgot that sometimes they aren't fully reliable,
Saludos, Andrew
Andrew
Tak FSQ-85ED
Moravian G3-16200
QHY9C
