The approach I was suggesting avoids the lrgb tool.
Once you have adapted your stretched L and RGB, open the channel combination tool, select cielab, select yor L as luminance, disable the other two flags.
Then drag the instance to your RGB.
If you decide for linear fit to adapt the image there is no need to actually decompose the RGB, just extract the luminance to get the reference.
Using Hdrwt on the L is normally a good thing, On color data I don't know ( never tried)
Andrea
