Author Topic: ATrousWaveletTransform not working in 1.08.04.1185 Ripley (x64)  (Read 3420 times)
Offline dwultrabike
Just updated to 1.08.04.1185 Ripley (x64)
Now when I apply the ATrousWaveletTransform, only 1 small section or band of the image gets changed.
Also the preview is acting strange while dragging the bias slider. Sometimes only a single band of the image shows and sometimes the bias jumps back to 0 even though the slider is far to the right.
This occurs on both my Windows 7 desktop and Windows 8.1 laptop systems.
The ATrousWaveletTransformV1 seems to work fine, but there is no preview.
Re: ATrousWaveletTransform not working in 1.08.04.1185 Ripley (x64)
« Reply #1 on: 2015 October 15 01:50:23 »
Please install all available updates. This bug has been fixed several days ago:
http://pixinsight.com/forum/index.php?topic=9112.0
Offline dwultrabike
« Reply #2 on: 2015 October 15 09:36:00 »
I get the dialog "There are no updates currently available for your Pixinsight installation"
I uninstalled, re-installed and re-updated both PC's, ATrousWaveletTransform is still not working for me.
And yes MultiscaleLinearTransform does work just fine with the updates.  And the "parallel --disable" work-around does work for the ATWT.
Dave
« Last Edit: 2015 October 15 18:46:54 by dwultrabike »
« Reply #3 on: 2015 October 21 13:11:14 »
ATrousWaveletTransform is an obsolete process, so it has not been included in the update that we have released to fix this problem. ATWT will work correctly in the next version of PixInsight (1.8.4.1187, almost ready for release on Linux, OS X and Windows), but it should not be used in new projects. It is kept only for compatibility with existing projects, and will eventually be removed from the official distribution.
Please use the MultiscaleLinearTransform tool, which has superseded and replaces ATrousWaveletTransform.
Offline fkloer
« Reply #4 on: 2015 October 22 12:06:24 »
Juan -
I use ATWT to process solar images after I have stacked the AVI's. It works great! Can I use MultiscaleLinearTransform for this also?
Good viewing, Clear skies
« Reply #5 on: 2015 October 22 12:53:38 »
The MultiscaleLinearTransform tool has the same features as ATWT but adds the Multiscale Linear Transform algorithm and the Linear Mask. Just select the Starlet transform algorithm and use your previous ATWT settings.
