Author Topic: PJSR Win7 1171 & 1123: Math.initRandomGenerator problem  (Read 4447 times)
Offline mschuster
« on: 2015 October 02 17:42:34 »
Hi Juan,
Low priority on this.
On Win7 both 1171 and 1123:
I want to seed the random number generator to repeat a random sequence for testing purposes. See attempts below.
When I use randomSeed32 I get a runtime error. initRandomGenerator is documented to take a uint parameter but this variant does not seem to work:
   if (true) {
      var seed = Math.randomSeed32();
      console.writeln("seed: ", seed);
      var random = Math.random();
      console.writeln("random: ", random);
      Math.initRandomGenerator(seed);
      console.writeln("initRandomGenerator: ", seed);
Edit: I was able to get randomSeed64 to work. I see now that multiple inits will generate the same sequence, but this sequence does not match the one following the seed call.
« Last Edit: 2015 October 02 18:33:27 by mschuster »
Re: PJSR Win7 1171 & 1123: Math.initRandomGenerator problem
« Reply #1 on: 2015 October 05 02:26:49 »
Hi Mike,
Simply specify a constant seed. For example:
      Math.initRandomGenerator( [3714832114, 2224669678] );
This ensures that the pseudo-random sequence is always the same on each execution.
The Math.initRandomGenerator() method has a bug because it only accepts 64-bit seeds. I have just fixed this bug in the next version; thank you for discovering it.
