Author Topic: Hello World! + Evaluating KAF8300 Darks  (Read 2350 times)
Offline silios
« on: 2015 September 28 13:39:28 »
Hello pixinsighters :D
First of all, congratulations to all the people involved, for the awesome software!
I have been using pixinsight for some time now and recently started to look more into my processing in general.
While i was looking at my integrated master dark frame i see alot of (i think Hot pixels) and no matter what sigma settings i set in the ImageIntegration tool i always get the same weird pixels in the final.
That happens only while doing an auto stretch. If i strech the image with the histogram tool the "hot pixels - lumps" seem to be gone or better blended into the rest of the noise.
There is also something like amp glow - banding in left of the Dark frame as well..
Is that normal with a Sbig 8300m or do i have hardware - software (settings) issues?
Attached image is 50 dark frames 1x1 1800secs at -5c stacked in image integration with usual settings per Vincent's
And here is the fit file if anybody wants to have a look https://www.dropbox.com/s/xkwp85d5eph0r1n/integration1.fit?dl=0
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: Hello World! + Evaluating KAF8300 Darks
« Reply #1 on: 2015 September 29 07:40:41 »
Silios,
First off, welcome to the Forum!  Hope you join us often as its a great resource.
As to your 8300 darks, I have two 8300 CCDs, an STF8300 and an STT8300.  Your master looks very similar to mine, though I typically shoot lights with these CCDs at 300 seconds or less (I use them with a very fast f3.3 astrograph).  As such, you show more hot pixels than I do, but that is to be expected since I run at colder temps and do not shoot my darks for longer than 300 seconds.
The key is what those darks do when you process your lights.  If they are cleaning up the images you are all set.  But if you are scaling, be sure to include a master bias frame and to check the calibrate and optimize buttons in the image calibration tool.  Dithering is also important, if you can manage it.  My first two steps in PI are to calibrate the lights, then run them through CosmeticCorrection using a sigma setting of between 2.5 and 3 for both high and low.  At that point you should have nice clean subs ready for testing with blink and SubFrameSelector.
If you are scaling and not setting up the calibration tool correctly, that could be what's causing your issues since you will be way out of line between your master dark and your lights and that leads to problems with hot pixels and cold pixels.  You can avoid this issue entirely if you shoot darks for the same iteration time as your light frames.  in that case you don't need the bias or to check any boxes in the calibration tool.
Hope that helps but if not report back and we can try something else.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline silios
« Reply #2 on: 2015 September 29 08:07:30 »
I will give the cosmetic correction a go for now as you suggested and make a dark library from scratch for different usual exposures.
might be looking at a faster instrument as well some time soon, cause living in Athens, Greece is hot + light polluted which leads to 20minutes NB and -5c cooling point  O0
Thanks Jim,
