Author Topic: more trouble with flats  (Read 3274 times)
Offline alcol
« on: 2015 September 17 12:50:24 »
Looking for guidance
I have followed the tutorial regarding pre-processing. Used my super bias and master dark to calibrate my flats (taken by imaging a laptop screen with Notepad filling the screen) Up until a few weeks ago I didn't bother with flats as the DSLR camera was clean, now I have a large dust mote somewhere in the imaging train and I need to remove it with flats.
I have the following problem. When using the super bias, master dark and the master flat produced I get a very red image. The image is still bright red after using the Screen Transfer Function, with a hint of stars showing through. Using the Background extractor shows the image, but it still has lots of reddish gradients which I can't get out using post-processing techniques.
If I calibrate the Lights only using the super bias and master dark and no master flat, I get what looks like normal images. The bright red has all gone. However, with no flats applied the dust mote is in evidence and spoils the image. The Master Flat produced after calibrating with the bias and darks does show up the dust mote, but somewhere it is destroying the calibration of the Lights.
The images are still bright red if I only use the super bias and the master flat. Calibrated the Flats just using the super bias but still end up with the bright red image!
Any assistance, guidance would be very welcome. Please don't be too technical and PI is relatively new to me.
Alec
Re: more trouble with flats
« Reply #1 on: 2015 September 17 16:54:49 »
Hi Alec, is it possible to upload the images? I would like to inspect one ligth and the masters.
Saludos, Alejandro
Offline alcol
« Reply #2 on: 2015 September 18 04:32:31 »
Hi Alejandro
How do I send these files to you?
Regards
Alec
« Reply #4 on: 2015 September 19 10:07:56 »
Hi Alec, maybe your Masterflat is too dark, however all seems to work fine.
Attached is an image with the parameters in ImageCalibration tool.
Remember the Ctrl+AutoStretch to apply STF in unlinked mode.
Saludos, Alejandro.
Offline alcol
« Reply #5 on: 2015 September 19 11:47:21 »
Hi Alejandro
Thanks for taking time to investigate.
When I put the same files into my copy of Pixinsight I still get the same red image. Not sure what I am doing different my screen shot is attached. I run Image Calibration and debayer the result and then do an autostretch and get the red image?.
See attached
« Reply #6 on: 2015 September 19 12:01:37 »
You are only missing the autostretch with unlinked channels. Press the button that says "Link RGB channel" in STF and Auto stretch again.
Saludos, Alejandro.
Offline alcol
« Reply #7 on: 2015 September 19 13:08:58 »
Hi A
Just did that and it worked - Magic!
I can't say that I have used this before, I always simply click the STP Auto Stretch and it has always worked before?
Very, very many thanks for making an old man happy.
Take care
Alec
« Reply #8 on: 2015 September 19 15:37:13 »
a pleasure Alec!
Saludos, Alejandro.
