Author Topic: StarAlign is changing image statistics  (Read 2287 times)
Offline cbradshaw
    • Charlie's Tree House Observatory
« on: 2015 September 16 17:19:48 »
Star Align is changing my image statistics during registration.  I've tried several times but my 60 second exposures look quantized.  Nebulosity registers the images fine and 300 second exposures are fine.  It appears an artifact of the counts not being very high.  I tried to manually select the output format, but with the same results.
All help welcome,
Charlie
Charlie - G11, CGEM, SV115T20, Meade SN8, Mod Canon 20d and T3, QSI 683 WSG,
Re: StarAlign is changing image statistics
« Reply #1 on: 2015 September 17 01:44:22 »
Indeed. This is a normal consequence of pixel interpolation. If you want your statistics preserved (but at other costs), use nearest neighbor.
Try enabling 24-bit STF LUT tables (IMAGE > Screen Transfer Functions > Use 24-bit STF LUTs). See this forum post, where 24-bit STF LUTs are described.
Fine!
Offline cbradshaw
« Reply #2 on: 2015 September 20 15:40:39 »
Thanks Juan!
My confusion was the 300 second exposure interpolation statistics were not changed, only the 60 second exposures.  I would have expected both to be changed if it was the interpolation algorithm.
Thanks for the 24 bit STF LUT information.  I will give it a try.
The fine for Nebulosity is that the registered images are not strongly quantized.
Charlie
