Author Topic: Picture FIT or TIFF format in Gray --> Conversion to color  (Read 2296 times)
Offline Leandro VARGAS
« on: 2015 September 01 05:17:12 »
Hello,
I'm starting to use my new camera QHY10 colour with Maxim DL.
The pictures taken in FIT or TIFF format to be opened in PI, all the time when I open the picture I saw in gray.
For the format RAW (DSLR Camera) we have format option exists for debayer RGB to colour pictures.
you can indicate in PI for the TIFF or FIT format as possible converted gray to colour, which is the menu option or parameter to be used.
I will appreciate very much your comments.
Thank you,
Leandro
Offline gvanhau
Re: Picture FIT or TIFF format in Gray --> Conversion to color
« Reply #1 on: 2015 September 01 13:42:48 »
Hello Leandro
Unless you calibrate and integrate pictures in Maxim, the right way to proceed is import raw cfa images (gray).
If you firt debayer then the calibration will not work properly.
Hola Leandro
Si entiendo bien tu pregunta,
a menos que hagas la calibraciĆ³n e integraciĆ³n directamente en Maxim, la forma correcta de importar las imagenes es en gris sin debayerizar. Sugiero usar formato Fit.
Si importas las imagenes ya en color estas incorporando datos interpolados los cuales no van a permitir calibrarlas correctamente.
Saludos
Geert
Geert Vanhauwaert
« Reply #2 on: 2015 September 01 20:27:52 »
Thank very much Greert.
Muchas gracias Greert.
