Author Topic: Difficult background extraction  (Read 2056 times)
Offline LorenzoM
    • My pictures
« on: 2015 August 23 10:12:37 »
Hi, I stopped for several month from astrophotography but now here I am starting with RGB imaging for the first time.
I decided to try with NGC6914, reflection nebula in cygnus and acquired 12 images of 10 minutes for each channel, no L data yet. The telescope is a FSQ106 coupled with sbig ST2000XM camera.
Unfortunately data have been acquired close to street lights and a green gradient appears. I tried to remove it with background extraction but I have not found a way yet to do it in a successful way and gradient persists also after correction.
I am not very good with this tool so please can you give a look?
If you want please continue also with image processing up to the end, but post here the result and passages if you do it; it is my first RGB.
Thank you for your help.
Here you can download the data https://www.dropbox.com/s/hfforxys1kjam8e/rgb.rar?dl=0
Each channel has been calibrated with flat and dark and registered to each other.
« Last Edit: 2015 August 23 10:25:50 by LorenzoM »
Matter suggests to space as it needs to bend;
space returns the favor suggesting to matter as should moves
'John A.Wheeler 'Spacetime Physics'
http://www.flickr.com/photos/lorenzomassimi/
Re: Difficult background extraction
« Reply #1 on: 2015 August 23 16:22:51 »
Hi Lorenzo
Let me explain what I did. First I combined the 3 images with ChannelCombination. Then I applied STF unlinked. I then used AutomaticBackgroundExtractor(ABE) with the settings shown in the image below. This was just a very quick look. I'm sure others can get a better background. I have not done anything else to the image at this point.
