www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
Bug Reports
Clone tool bug ?
« previous
next »
Print
Pages: [
1
Author
Topic: Clone tool bug ? (Read 2806 times)
JGMoreau
PixInsight Addict
Clone tool bug ?
on:
2015 August 23 07:21:57 »
I noticed something wrong with the clone tool brush as it leave
a string of bright pixels as you drag it across an image.
A bug or some setting i should change ?
Win 10, 64 bits, 8Gb ram.
Logged
NGC7789
PixInsight Old Hand
Re: Clone tool bug ?
Reply #1 on:
2015 August 23 08:01:03 »
Do you mean the line from the circle to the "x"? If so that's as designed. It indicated the "copy from-to" path.
Logged
JGMoreau
PixInsight Addict
Reply #2 on:
2015 August 23 08:11:10 »
No, if you look closely at the attached image, you should notice a line of dots,
apparently left from the top right branch of the X as the tool is dragged on the image.
Version 1171 btw.
JG Moreau
Québec
Logged
PTeam Member
PixInsight Jedi Grand Master
Reply #3 on:
2015 August 23 08:46:43 »
This is obviously a screen rendering bug. Interestingly enough, it doesn't happen on Linux, Windows 7 and Windows 8.1.
This bug is completely harmless; it just affects the screen rendition of the cloning source mark (based on your screenshot, as I cannot reproduce the problem). So just ignore it; I'll fix it in September. Thank you for reporting.
Logged
Alejandro Tombolini
PTeam Member
PixInsight Jedi
Reply #4 on:
2015 August 23 10:23:08 »
Hi Juan, if it helps I can reproduce it in Linux with CloneStamp and also with DynamicAlignment. My monitor is 1920x1080
Saludos, Alejandro.
Logged
msmythers
PTeam Member
PixInsight Jedi
Reply #5 on:
2015 August 23 16:46:07 »
Juan
I have it also with CloneStamp and DynamicAlignment. It seems to be somewhat directional. When I pulled the mouse from top right to bottom left it shows but I did not notice or just didn't see it going the other direction.
Windows 7 2560x1440
Logged
Print
Pages: [
1
« previous
next »
PixInsight
Bug Reports
Clone tool bug ?
