Author Topic: cosmetic correction produces black images with xisf  (Read 2448 times)
Offline TobiasLindemann
    • Trackingstation
« on: 2015 August 22 10:01:14 »
If you use cc with xisf files and want to save them as fit, it produces black images. This is no great problem, because if you save as xisf it works perfect. Although someone (e.g. me ;-)) will be irritated when using old icons, where fit was the default output extension.
Greetings
Tobias
Re: cosmetic correction produces black images with xisf
« Reply #1 on: 2015 August 22 11:01:18 »
Tobias
Is it possible that you were using STF? The latest software revision now saves the STF state for xisf files. It doesn't do that for other formats like fit I believe.
