Author Topic: Bug in Pixel Math  (Read 2381 times)
Offline Dimitris Platis
Bug in Pixel Math
« on: 2015 August 22 06:01:09 »
I am trying to do harry's trick for switching narrowband stars with RGB stars (same algorithm like when changing Masked Stretch stars with HT stars).....however, it doesnt work unless I click Replace Image.
When I click New Image it just creates the image written on Pixel Math.
Is it a bug or am I missing something?
Re: Bug in Pixel Math
« Reply #1 on: 2015 August 22 09:26:45 »
you apply this thru a mask, right?
i guess what's happening is that when you don't use "replace image" you get a copy of the original image, which is correct. if you were to use replace image without a mask, you'd overwrite the whole target image with the source image. but since you are using a mask, only those pixels exposed by the mask are written by pixelmath.
i think if you want a new image of just the changes, you'd have to use the pixelmath expression star_mask*rgb_stars (or maybe ~star_mask*rgb_stars).
