Author Topic: When to combine Ha with RGB?  (Read 3276 times)
Offline joelshort
    • Buckeyestargazer.net
« on: 2015 August 18 12:26:36 »
When is a good time to combine Ha data with R(GB)?  Linear or non-linear?  Earlier in the process or later?
Joel Short
www.buckeyestargazer.net
Offline JoLo
Re: When to combine Ha with RGB?
« Reply #1 on: 2015 August 18 13:51:22 »
I extract the RGB components after background / color calibration while in the linear state.  In my workflow, i have already performed non-linear noise reduction at this point.  The extracted R component is then combined with the Ha narrowband, and the RGB image is recomposed using the R/Ha hybrid in the red channel.
Joe
Orion Atlas
AT106
AT65
Canon 450D
Atik 314L+
Orion 12" Dob
Offline lucchett
« Reply #2 on: 2015 August 19 05:42:55 »
If you are adding ha to R, I would do this in the linear stage. If you want to mix also ha in
L you have better to do this after stretching. This because I think the Cie Lab space is non linear.
I know it is possible to do the same in the linear stage but you should first apply a linear color space, which is something I couldn't personally master till now
Andrea
Offline jerryyyyy
    • Astrobin Images
« Reply #3 on: 2015 August 19 11:55:15 »
You may want to compare your results using the AIP and NBRGB scripts.  I think both allow linear versus nonlinear inputs.  This gives you a 2x2 matrix of possibilities x the various settings of each script for a lifetime of processing....  :surprised:
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline JoLo
« Reply #4 on: 2015 August 19 13:00:00 »
In my experience, it is much better to hybridize Ha with R, rather than a standalone channel in RGB combine, or with a luminance image.  This produces much better color in the final result, the others tend to produce the sickly salmon color you often see in Ha combined images.  I always normalize the color space with RGBWorkingSpace prior to splitting into R, G, B and combining the Ha with the R.  I never use L*a*b color space in this process.
It varies from image to image, but play with the percentages of Ha and R in the hybrid, then recombine to form the new HaRGB and assess.  Sometimes more Ha, sometimes less....
Orion Atlas
AT106
AT65
Canon 450D
Atik 314L+
Orion 12" Dob
Offline topboxman
    • Peter's Gallery
« Reply #5 on: 2015 August 19 16:06:46 »
Hi Joe,
I am interested in your procedure. I see that you do this:
1) RGB Combine
2) Background Neutralization
3) Color Calibration
4) Extract R, G and B from RGB combined
Then I am curious is whether you do any processing of Ha before blending it with R? Do you do LinearFIT of Ha with R first before blending Ha with R? Do you Pixel Math for Ha combined with R? If so, what are your typical Pixel Math equation?
Peter
