Author Topic: Minor issue TreeBoxNode.setBackgroundColor broken?  (Read 4400 times)
Offline mschuster
« on: 2015 August 09 15:47:59 »
I believe TreeBoxNode.setBackgroundColor used to work, but does not now, neither in 1123 nor 1171. Background stays white in Win7 always.
Re: Minor issue TreeBoxNode.setBackgroundColor broken?
« Reply #1 on: 2015 August 11 12:10:17 »
Hi Mike,
True. I'll try to fix this issue in the next version.
Try with the following style sheet (for example):
QTreeView::item {
   background: green;
This style sheet has to be set for the parent TreeBox control. Unfortunately, it doesn't work on a per-item basis, so I suspect this is not what you want...
