Author Topic: 1.8.4.1171 Win7 Script Editor window issue?  (Read 5457 times)
Offline mschuster
« on: 2015 August 06 12:37:21 »
Open several files in the Script Editor.
Attempt to drag the vertical divider between the file pane and the text pane, drag the divider left and right various distances without releasing the mouse button.
The file pane pops in and out of view and and both panes are clipped in some situations. The file pane also sometimes disappears from the window when the mouse button is released. Restoring pane visibility seems to require a Reset Pixinsight Settings operation.
Re: 1.8.4.1171 Win7 Script Editor window issue?
« Reply #1 on: 2015 August 11 12:19:09 »
I don't see this problem on Linux. I'll try on Windows and will let you know. Thanks for pointing this out.
