Author Topic: Ripley 1.8.4 running error after installation  (Read 3486 times)
Offline federico
  • A brilliant future behind
    • Business site
« on: 2015 August 05 03:40:36 »
Hi all,
after installing 1.8.4 on my Ubuntu 12.04, PixInsight refuses to run. Once tested from console:
./PixInsight.sh
/opt/PixInsight/bin/./PixInsight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.17' not found (required by /opt/PixInsight/bin/./lib/libssl.so.10)
/opt/PixInsight/bin/./PixInsight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.17' not found (required by /opt/PixInsight/bin/./lib/libcrypto.so.10)
Not sure on how to fix - it seems I've to compulsory upgrade to the last UBUNTU version. But this is my work PC, full of development packages...any advice?
Thanks in advance
Federico
Re: Ripley 1.8.4 running error after installation
« Reply #1 on: 2015 August 05 04:59:23 »
As far as I know there is no way to provide an old OS with a newer glibc version. It is closely coupled to your OS version. So you either have to upgrade Ubuntu, or ask Juan to compile PI with an older glibc, or you run a newer OS in a virtual machine.
« Reply #2 on: 2015 August 05 06:25:53 »
Yeah. Installing a newer glibc is not recommended. I once tried, and ended with several problems. I just upgraded.
I don't know how it is working on ubuntu right now, but the past upgrades of the system I did using Fedora were pretty much seamless. I just faced some problems related to the graphic controllers, but overall, everything worked better.
Another option: how about adding an HDD (or SSD) and installing there a newer version?
« Reply #3 on: 2015 August 10 02:08:21 »
Hi Federico
Version 1.8.4 of PixInsight for Linux requires glibc version 2.17 or later. Ubuntu 12.04 (April 2012) is definitely a bit on the dated side.
In September we are going to change all of our development machines to RedHat Enterprise Linux 7, which will replace Fedora. This means that glibc 2.17 (released December 2012) will be required by all future Linux versions of PixInsight for a long time.
Offline AstroMatt
« Reply #4 on: 2015 August 14 10:52:13 »
Any word on when the MAC update will be released?
Thanks1
« Reply #5 on: 2015 August 19 10:55:34 »
Hopefully, a 1.8.4 version of PixInsight for OS X will be released in September. However, we are facing very complex code adaptation problems and bugs in third-party development tools, which require a lot of coding and testing work, so I am not completely sure.
