Author Topic: File selector showing no files in v01.08.04.1170  (Read 3170 times)
Offline jbinpg
« on: 2015 August 04 02:22:21 »
Installed latest core v01.08.04.1170 update. Unable to load any DSLR light files from selector panels. File selector panels show as empty with either "any supported format" or "DSLR_RAW" file type selected. Interestingly, in the Preprocessing batch script, I can see the greyed out files when selecting the output directory. Also happens when I try to load files into individual process modules rather than a batch script.
Here is my /etc/ld.so.conf:
include /etc/ld.so.conf.d/*.conf
include /opt/PixInsight/bin
include /opt/PixInsight/bin/lib
Any troubleshooting suggestions welcome.
Jack
Offline jbinpg
Re: File selector showing no files in v01.08.04.1170
« Reply #1 on: 2015 August 04 02:50:36 »
More on this. I found that with "Accept dropped files" checked in Global Preferences, I can successfully drag and drop files from the nautilus window in Ubuntu 15.04 onto the file selector window in PI and the files will show up. Strange bug.
Jack
« Reply #2 on: 2015 August 05 06:43:16 »
I cannot reproduce it in Fedora with 1171. CR2 files are loaded fine here from the standar dialog and the file explorer.
Is your file explorer working fine?
You may try changing the global options, under File I/O Settings, and check to use native file dialogs, and see if that works better.
« Reply #3 on: 2015 August 05 06:54:02 »
I can't reproduce this either on any of our Linux workstations with KDE and GNOME. Admittedly, I haven't tested PixInsight 1.8.4 on Ubuntu 15, but this problem is really odd to say the least. Might be a rare interaction with GNOME.
Offline starhopper
    • starhopper
« Reply #4 on: 2015 August 05 09:15:16 »
Hello,
I can confirm this behavour on my Linux Mint Workstation. I think it is a upper/lowercase issue. None of my DSLR RAW images are shown in the open dialog of pixinsight. My Canon EOS uses uppercases. Converting the file names to lowercase resolved it. Maybe it helps.
Thomas
Thomas Jäger
https://www.starhopper.eu
12"f/3.8 & 8"f/2.9 Astrograph
SBIG STL11000M, Moravian G2 8300
Vixen Atlux Mount, Skywatcher AZ-EQ6 GT
Skywatcher Esprit 100/550
« Reply #5 on: 2015 August 10 01:57:07 »
Seems to be a duplicate of:
http://pixinsight.com/forum/index.php?topic=8814.0
We can't reproduce this behavior on any of our Linux machines. File format suffixes are always case-insensitive in PixInsight by design, so this looks like a problem at the desktop manager level.
Are you using native file dialogs? Try changing this option:
- EDIT > Global Preferences
- Preferences > File I/O Settings > Use native file dialogs
Offline starhopper
    • starhopper
« Reply #6 on: 2015 August 24 11:39:19 »
Sorry for the delay, I was on vacation.
The use of the native file dialog as described above does not solve this behavour.
Thomas
« Last Edit: 2015 August 25 06:01:44 by starhopper »
Thomas Jäger
