Author Topic: Lanczos Resampling Issue  (Read 4224 times)
Offline akulapanam
« on: 2015 July 28 19:55:47 »
In order to register my osc ha frames to my rgb frames I have been using the Lanczos resampling method. Unfortunately last night I realized that this was causing extensive ringing and in general noise. I tried changing the clamp with out effect and then tried a couple other methods. The good news is the other methods resolved the issue but the bad news is the overall brightness and contrast of the image decreased dramatically. Any ideas on how to get the best of both.
Re: Lanczos Resampling Issue
« Reply #1 on: 2015 July 30 04:07:14 »
Interpolation algorithms and their implementations in PixInsight are reasonably documented:
http://pixinsight.com/doc/docs/InterpolationAlgorithms/InterpolationAlgorithms.html
This documentation is a bit outdated (we now have better implementations), but the essential information is there. You are facing the eternal dilemma between ringing and aliasing. Each data set poses completely different problems and requires different solutions.
Just a note about a common caveat: if you are tempted to use the bicubic B-spline algorithm, be advised that this is probably the worst choice. Bicubic B-spline implements an old resampling method by Paul Bourke and is being kept in PixInsight for historical and compatibility reasons. This algorithm will be removed in a future version. Also try to avoid bilinear interpolation, as it is the worst option in terms of aliasing.
Offline akulapanam
« Reply #2 on: 2015 July 30 15:58:40 »
What about the brightness vs contrast issue?  Also what would you recommend instead of lanczos?
Offline akulapanam
« Reply #3 on: 2015 August 02 11:42:41 »
Version A used Lanczos in PixInsight to Resample Ha to RGB- best stars but lost blue nebula, very grainy, stars have severe ringing at 100%. Deconvolution and HDR can't be used because of grain
http://www.astrobin.com/199104/0/
Version B used B-Spline in PixInsight to Resample Ha to RGB
http://www.astrobin.com/199104/B/
Version C used B-Spline in another program to Resample Ha to RGB
http://www.astrobin.com/199104/C/
Offline akulapanam
« Reply #4 on: 2015 August 02 14:43:51 »
Here is a much better comparison. I cropped each to IC1284 itself at 100% zoom.  The original image is close to 9mp.
http://www.astrobin.com/full/199142/0/
« Reply #5 on: 2015 August 03 07:06:34 »
So you've found "another program" that works a treat. Congratulations, but this forum is for "this program", not for "another program". The documentation linked above describes ringing and the options you have to prevent it in PixInsight. Bicubic spline interpolation (not to be confused with bicubic B-spline) is one of them when the source data is too weak for Lanczos. If you don't like our implementations, or if you think they don't work for you, then use "another program". Just bear in mind that we are not really interested in "another program" here, just "this program".
Offline akulapanam
« Reply #6 on: 2015 August 03 14:44:31 »
That really was not my point. I think the b-spline in PixInsight produces acceptable results although I'm not sure why it changes brightness/contrast.   The other program lanczos has the same issue has pixinsight.  Right now I'm trying the PixInsight drizzle approach and we will see what happens.
Offline akulapanam
« Reply #7 on: 2015 August 03 20:40:19 »
So here is the version of the image using drizzle.  Not too bad but pretty grainy.  I had to dump on noise reduction.  Also for some odd reason my drizzle stack ended up a little left which is why part of the right is cropped off.
http://www.astrobin.com/199104/D/
