Hey Barry,
Some tips on doing this:
- I've tried this before and after calibration and had much better success doing it before calibration
- Do a maximum integration of all your un-registered images. I started doing this specifically for DBE so that I could find sample locations that didn't overlap any stars.
- Test your ABE parameters with that image
- I would use a very low function order so that it only catches gradients and not things like vignetting (which can persist after calibration in the presence of strong LP gradients). Something on the order of 1 or 2.
- Make sure to set it to subtraction mode and enable the normalize option so that the background levels are maintained
After you do your pass of ABE then run your normal calibration, registration, integration, etc. I've had good success doing it this way, but certainly trying other options is good and may provide you with better results for your data set.
David
