Author Topic: Save All  (Read 1949 times)
Offline Gordb
Save All
« on: 2015 July 18 00:39:42 »
I've seen that this topic has come up before in different contexts.  I am using a Canon 600d with BYEOS as my capture software.  The output is either CR2 or TIFF.  I 'm looking at Cosmetic Correction and in order to add files they need to be in FIT format.  I can, for example, open a CR2 file and save it as a FIT file which is then available for Cosmetic Correction.  This is fine for a few files but if you have several to convert to FIT it becomes quite tedious.  In this example, is there a way to open all CR2 files and then do a save all to save them as FIT files?  Or is there a batch conversion that allows this to occur?
Many thanks,
Gord
Offline Gordb
Re: Save All
« Reply #1 on: 2015 July 18 09:37:19 »
Hi.  Just found my answer with BatchFormatConversion.
Gord
