Author Topic: Color calibration before or after DBE?  (Read 2988 times)
Offline astrovienna
« on: 2015 July 15 08:13:46 »
I've seen processing walkthroughs from some of the experts that use DBE before color calibration/background neutralization, and some that do it after.  Does it matter?
Kevin
Offline lucchett
Re: Color calibration before or after DBE?
« Reply #1 on: 2015 July 15 08:31:26 »
I think there's general agreement that DBE should be run first, otherwise you perform a wrong calibration based on "polluted data".
Andrea
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #2 on: 2015 July 15 13:44:58 »
I agree with Andrea.  I think its important to clean up the document re gradients, etc through DBE before doing the color calibration.
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline lucchett
« Reply #3 on: 2015 July 15 13:51:28 »
well, i think I've found a possible exception which I cannot explain.
I have one image in which I am personally unsure if there is a gradient or not.
After spending hours with DBE, I realized that it was mainly a calibration problem and a peculiar shape of the nebula.
color cal alone works quite well.
doing dbe after cc seems to improve further my result, which is a bit contraddictory.
The only reason I se is that my DBe model is probably wrong.
I am going to post the image in the "processing challenge section"
Andrea
Offline astrovienna
« Reply #4 on: 2015 July 16 10:05:31 »
Thanks for the advice.  I'm still trying to get my LRGB process to fall into place, so this helps.
Offline Warhen
    • Billions and Billions
« Reply #5 on: 2015 July 18 13:10:14 »
Absolutely! How can we hope to get a nice color calibration with lovely cyan and magenta gradients lurking about? BM, then BN, then CC and you're off! :>)
Best always, Warren
Warren A. Keller
www.ip4ap.com
