Author Topic: Re-sizing Adapter Stretch Real Time Curve Graph  (Read 3392 times)
Offline niteman1946
« on: 2015 June 29 15:14:26 »
Hi Group,
I've come hat in hand for some help.  I've managed to size the curve graph to its largest size.  With that I find that I cannot re-size the graph back to something that fits within the screen.
The lower portion, with the size drop-down window and other buttons, falls below the monitor screen and is not accessible.
I'm running version 18-1123, 64 bit.  Monitor is at 1440x900 resolution.
Here's a screenshot showing the white curve graph.  The graph is to the top of the screen and consequently, its lower section is unavailable.
I've tried all my "A" material, but so far nothing has worked.
Mark
Re: Re-sizing Adapter Stretch Real Time Curve Graph
« Reply #1 on: 2015 June 29 17:31:46 »
Hi Mark, interesting, can you increase the resolution of your monitor?
Offline niteman1946
« Reply #2 on: 2015 June 30 04:29:10 »
Hi Alejandro,
No, I'm at the max.  I've tried lowering it with no success.
Also, restarting, rebooting, etc. has done no good.  Neither has re-sizing the PI window.
Somewhere I have notes from Juan on "re-setting" PI.  Reckon that's where I'm heading?
Mark
Offline Cosmick
« Reply #3 on: 2015 June 30 04:44:47 »
Try using the UP arrow on your key board. If it does not work the first time hit the TAB key once or twice, to highlight the size field, and then use the UP arrow to change the size.
Clear Skies
Mick
Offline niteman1946
« Reply #4 on: 2015 June 30 05:07:10 »
Genius Mick,
that did the trick.
Mark
« Reply #5 on: 2015 June 30 05:09:04 »
Mick's trick is very clever. Since the only control that can have the keyboard focus on the graph window is the size selection combo box, if you click the curve graph and press the up arrow key a smaller window size will be selected and applied immediately.
Sorry for the inconvenience. I'll think on a way to prevent this problem on small monitors (putting the controls above the graph can be a simple solution).
« Reply #6 on: 2015 July 01 20:13:00 »
Hi, added a little video that shows it.
Saludos, Alejandro.
Offline niteman1946
« Reply #7 on: 2015 July 02 12:22:30 »
Thanks Mick, Alejandro and Juan.
I really appreciate your willingness to help with this. :)
Mark
