Author Topic: Calibrating and stacking spectra?  (Read 2548 times)
Offline Gasman
« on: 2015 June 26 11:42:19 »
Hi guys
I`m now taking spectra using a slit type spectroscope that only shows the spectrum of the star and doesn`t show the star itself, a grab of a spectrum taken of P Cyg the other evening is attached. I`m trying to find a way for PI to stack and calibrate these fits files but the batch preprocessing script is looking for a minimum of 6 stars which obviously are not available with these spectrum files and I wonder if there is another way I can stack/align these with PI please?
thanks
Offline TobiasLindemann
    • Trackingstation
Re: Calibrating and stacking spectra?
« Reply #1 on: 2015 June 27 15:41:49 »
Hi Steve,
calibrating should be no problem. Activate the checkbox "calibrate only" in the BatchPreprocessing. As you know "StarAlignment" registration don't work, because you have no stars. Have you tried the "FFT-Registration", which you can find in "scripts->utilities". I have tried this with your jpeg and two shifted versions of it and it worked.
Greetings
Tobias
« Last Edit: 2015 June 27 15:50:03 by TobiasLindemann »
Offline Gasman
« Reply #2 on: 2015 June 28 15:23:05 »
Hi Tobias
Many thanks for the info. Not sure what happens with FFT-registration but the resulting profiles of 10 betaLyra spectra and 10 PCyg spectra (blue in the attachments) have much smoother profiles than without so looks a very useful tool  :)
cheers
« Last Edit: 2015 June 28 15:41:34 by Gasman »
    • Trackingstation
« Reply #3 on: 2015 June 29 08:28:50 »
You are welcome.
Nice spectra :-)
