Author Topic: Elongated stars  (Read 3528 times)
Offline gianpri
Elongated stars
« on: 2015 June 13 12:44:46 »
Hello everyone. It exists in PixInsight a tool to repair the elongated stars? Thanks
Giovanni
Offline Dimitris Platis
Re: Elongated stars
« Reply #1 on: 2015 June 15 02:59:57 »
I found that the Morphological Transformation tool works great if u adjust the shape of the dotted square...!!
Offline gianpri
Re: Elongated stars
« Reply #2 on: 2015 June 16 08:06:13 »
Thanks Dimitris
Offline Warhen
    • Billions and Billions
Re: Elongated stars
« Reply #3 on: 2015 June 22 14:40:34 »
Gio, Try the Motion Blur tab of Deconvolution with a star mask in place! When selected, the Motion Blur PSF tab can repair star elongation (eccentricity) due to guiding error or opto-mechanical distortion. Use the Angle and Length sliders to define a pattern in the black preview box which matches the distorted stars in the image. Define a preview around several problematic stars, and try applying deconvolution with other settings at defaults. Drop Algorithm/Iterations to the lowest amount which achieves the desired effect. If the pattern of distortion varies across the field, masks would be needed to target the repair to specific parts of the image. Good luck!
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline Geoff
Re: Elongated stars
« Reply #4 on: 2015 June 22 20:53:22 »
It's OK to go ahead and try to salvage an image, but you should also try to get at the root of the problem---how can the guiding be improved to alleviate this.
Geoff
Don't panic! (Douglas Adams)
