So, at this point it appears that there are two conclusions.
1) PI cannot read the STF8300M 16-bit image files created by Maxim.
It does read files produced by other cameras in Maxim, ostensibly with the same format. I have been using an ST2000XM for years without problem; pfile has no problem with his FLI or STT-8300M, I have used various other cameras without issue. I will have to manually convert the STF-8300M files to float format for handling in PI.
2) Maxim changes the output format based on the image.
For example, PI can read the dark, bias, and flat frames from the STF-8300 without conversion, although they appear to be in the same 16-bit format as the image sub. When Maxim creates Master files they are in float format, not in the 16-bit format. The 16-bit images produced by the ST2000 are different from the STF-8300 somehow, perfectly readable in PI. Apparently the STT-8300 is also different.
3) There is clear sentiment that PI does a better job calibrating than Maxim.
I have not seen any studies on which program does a better job calibrating. I looked around on the net and didn't find anything, although hardly an exhaustive search. I have previously studied Star alignment results and found that PI does a better alignment than Maxim or RegiStar.
Clearly you guys feel that PI does a better job. This may well be true, although I can imagine that the software originating the image might have subtle tricks about calibrating it.
So, I did a bit of a test myself over the last 3 days, which I summarize here
https://brewobservatory.wordpress.com/2015/06/20/pixinsight-versus-maxim-subframe-calibration-comparison/. Basically,
- The Maxim calibrated image clearly appeared to have less noise visually.
- I have to be very careful with the calibration subs to get it to work in PI; many of the calibrations came out very poorly.
= The PI flat masters in particular seemed to be sensitive to failure. They often came out looking like bias frames.
= Interestingly, using float conversions of the calibration subs worked poorly. I had to use the original Maxim 16-bit subs for PI to get the calibration right. Makes me wonder if I will encounter problems with the float conversions of the light subs.
= Using Maxim's masters did not work. PI has to build its own masters.
= Creating a Superbias made things worse.
- I don't know how to measure noise very well; there are a number of tools in PI that report different things. However, these tools seemed to be contradictory in their results. Sometimes PI came out a bit better, sometimes Maxim came out better. I don't know if the measured values are significantly different.
So, for now it appears that my optimal solution is to continue to calibrate in Maxim and then convert the light subs to float for processing in PI.
