Author Topic: M31 and HDRWavelets  (Read 5147 times)
M31 and HDRWavelets
« on: 2008 September 21 11:42:07 »
I'm trying to apply the M101 tutorial http://pixinsight.com/examples/HDRWT/M101/en.html to an M31 image I took a while back. I'm not having much luck. The core keeps getting a ring around it. I used DBE to remove sky gradient due to the moon being present at the time (I know, not the best time to image).
Should I add a mask to the image and first process the core and other bright areas and then the dimmer ones by reversing the mask? Try a different process for getting some detail out of the core instead? Perhaps M31s core is more evenly illuminated than I thought. This is where the profile tool I asked for earlier would come in handy :)
I've uploaded a crop of the image in its current processing state. No stretches have been performed, just crops and DBE.
http://cid-a93625fef5ca95fb.skydrive.live.com/self.aspx/PixInsight/M31-crop.7z
Thanks for any insight you can provide!
I'll keep playing with this and maybe add some screenshots to show the effects I'm seeing.
Offline andyschlei
    • http://www.obsballona.org
M31 and HDRWavelets
« Reply #1 on: 2008 September 29 19:22:47 »
Sander,
I can't seem to access the image from the link you've provided.
--Andy
Observatorio de la Ballona
CDK 12.5, NP-101, C-11
AP-1200, AP-900
ST-10 XME, CFW-8, Astrodon v2 filters
Pyxis Rotator, TCF Focuser
M31 and HDRWavelets
« Reply #2 on: 2008 September 30 06:52:51 »
Hi Andy,
I just clicked on the link and it's there. It shows it's accessible to anyone. What's the problem you are experiencing?
Offline andyschlei
M31 and HDRWavelets
« Reply #3 on: 2008 September 30 08:22:01 »
I reports that it is a "7z" file.
What's the format?  FITS?
AP-1200, AP-900
M31 and HDRWavelets
« Reply #4 on: 2008 September 30 10:12:06 »
http://www.7-zip.org
An open source compressor. Whips FITS smaller than anything else I've tried.
Offline andyschlei
M31 and HDRWavelets
« Reply #5 on: 2008 September 30 13:27:02 »
Quote from: "Nocturnal"
Aaah.  I see.
That's a good thing to know -- zip doesn't do enough to make it worth using.
AP-1200, AP-900
Offline andyschlei
M31 and HDRWavelets
« Reply #6 on: 2008 September 30 19:49:12 »
Sander,
I took a stab at your image.
I converted to 32 bit integer
Rescaled
Stretched to visibility with histogram
Applied 2 iterations of HDR wavelet (4 was too many, 1 would have been OK too)
Stretched in curves to brighten
Stretched colors a bit in histogram.
Here is my result
A process container with all details as specified above is at this link
M31-Process.psm
HTH
--Andy
AP-1200, AP-900
M31 and HDRWavelets
« Reply #7 on: 2008 September 30 20:10:18 »
Hi Andy,
well that looks very promising! Thanks very much for doing this. I have since taken new M31 exposures so I will try your suggestion on that and let you know how it worked out.
