Author Topic: Is there a way to quickly preview a large number of images?  (Read 2554 times)
Offline astrovienna
I like to flip through my calibrated images to choose which ones to stack.  I had been using Nebulosity for this, but it won't work with the format now used by PI.  Is there an easy way to preview images in PI?
Kevin
Offline CharlesW
Re: Is there a way to quickly preview a large number of images?
« Reply #1 on: 2015 May 30 08:03:59 »
Have you tried the Blink process?
Offline NGC7789
« Reply #2 on: 2015 May 30 09:33:31 »
You can also use the subframe selector script to choose frames based on measured quantities like noise levels, FWHM of stars, etc. This doesn't let you view the frames per se but you can reduce the number you need to manually inspect and then use a tool like blink that Charles has suggested on the result.
Offline astrovienna
« Reply #3 on: 2015 May 31 07:15:04 »
Thanks guys.  That's exactly what I needed.  It makes glaringly apparent all the things I did wrong during capture!
Kevin
