Author Topic: Install Modules dialog crash  (Read 3841 times)
Offline David Serrano
« on: 2008 September 16 04:56:03 »
PixInsight can be reliably crashed by following this procedure:
- Move the config file out of the way (just to make sure this is a configuration issue).
- Go to the bin/ directory.
- Run "./PixInsight --no-splash --no-modules" (*).
- Go to Process > Modules > Install Modules.
- Since the default directory appearing in the dialog should be bin/, just click on the "Search" button.
- Click "Ok" on the dialog that says "26 modules were found".
- Click anywhere in the list of modules (a module name, a column header, the scroll bar). As soon as the mouse button is pressed, the crash dialog appears. The rest of the interface appears to work fine. You can also use <Tab> and <Shift><Tab> in order to give the focus to the list of modules.
Another less important bug:
- In the crash dialog, click on "Restart PixInsight". Now the splash screen appears and all modules are loaded, showing that this restart action ignored the user-specified command-line parameters.
* The --no-splash parameter isn't required, but helps to illustrate another point.
 David Serrano
« Reply #1 on: 2008 October 17 01:11:50 »
Hi David,
This bug has been fixed. It won't be present anymore in the new version 1.3, which is now in preparation for release.
The fix consists in that the Process > Install Modules and Process > Manage Modules actions are unavailable when the core application has been launched with modules disabled (i.e. with the --no-modules command line argument).
Thank you for detecting this important security gap.
Note that by restarting the core application (through File > Restart) all command-line options are implicitly reset, that is, command-line options are only taken into account in the first execution of the core application. This is by design, and is not a security issue since the decision to restart the application is completely up to the user, and scripts and modules have no way to trigger the restart action --unless they have been given permission to execute command-line commands, but again this is up to the user (who is supposed to know what he/she is doing when he/she changes security settings!).
