Author Topic: Master Flat Frames?  (Read 2665 times)
Offline sreilly
Master Flat Frames?
« on: 2015 May 18 18:32:20 »
What is considered a good number of flats to use to make the master flat. I've been using 72 with 36 for east and 36 for west side flats. Do I need this many or is there any advantage to more or less? I usually use 40-50 bias frames and 30 or more same temp/time darks for the master dark and bias frames.
Suggestions on best practices?
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline RickS
Re: Master Flat Frames?
« Reply #1 on: 2015 May 18 19:01:47 »
It depends on the characteristics of your camera.  For my camera, an Apogee U16M with KAF-16803, I target a total of 500K electrons (which is the point of diminishing returns according to a flat field PTC analysis.)  My full well is around 80Ke-, so at an ADU value in the middle of the range that's only 12 flats.  If you have a camera with shallow wells it will almost certainly be a much bigger number.
Without doing the PTC calculation, something around 30-40 flats sounds like a reasonable number for a sensor like the KAF-8300 (25Ke- well depth.)  You could always use the PI tools to do a noise analysis as you add more flats to your master and see where the improvement starts to drop off.
Rick.
Offline sreilly
« Reply #2 on: 2015 May 18 19:16:15 »
Thanks for the reply Rick. I guess I should have mentioned the camera is a STL-11002M and the other ST10-XME. Full well of the 11002 is 50,000 ADU and 77,00 for the ST10. I must say I haven't analysed the flats. So what is this PTC analysis?
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline RickS
« Reply #3 on: 2015 May 18 20:12:36 »
